- Joined
- 1 Apr 2016
- Messages
- 13,510
- Reaction score
- 543
- Country
So we had penetrating damp due to a bodged repair of a gutter which was leaking onto the sloping roof kitchen and causing penetrating damp.
The gutters have been repaired so not its onto the plaster. If you look at the pic below you can see its quite bad.
My plan is to move the cupboard and then strip all the damp plaster away from the wall back to the bricks? And also remove some from the ceiling.
Am I supposed to leave the wall to air and dry for a week before applying the new plaster.
I have read up and I am still a bit confused as to the process.
Do I use PVA bonding on the wall and then let that dry and then mix up bonding plaster and then apply that. Now as 95% of the damaged plaster is hidden behind the cupboard would I need to apply a finishing plaster ontop?
I think the whole area is about 2sq metres but I cant find anyone who wants to come out and do the job as its too small so having a go myself.
