- Joined
- 31 Dec 2018
- Messages
- 9
- Reaction score
- 0
- Country
I had my septic tank empty and since it wasn't cleaned properly the guy who cleaned it told me to open the cold water tap in the house and that was open for quite a while . When he left there was no hot water in the taps (there was a very low pressure coming and going until it was totally stopped) Read some about it and I think I have air locked in the system.
We have a cylinder (hot water tank) in the ground floor and a cold water tank in the loft. We also have a water pump as the water flow is weak. I saw a small valve that I screw off next to the cylinder hot water exit and felt air coming out along with hot water when it open and the water pump also start working as hot water going through it when the valve is open but it seems like the air in the system is endless as I open it for so much time and it still air comes out. I also scared as i read it could be dangerous and can explode ?
When closing the valve for sometime and then open the hot tap the stream looks normal and strong but after few seconds gets weaker and stops again.
Can anyone help please
