Hi, I've searched the forum and couldnt see this being asked before. I'm wondering what's the best way to strip back the PVC coating on a 10mm copper pipe, for soldering and visible sections into rad valves?
You can try pipe cutter or wire strippers.
Maybe try heating it as well. Just got to adapt and overcome really, same as getting oil paint off pipes. Shave it with blade and use edge of blade to scrape of remnants, then abrasive.
Flat blade and slice down the side to as far as you need and then run the blade round it and it should just pop off. It shouldn't be stuck to the pipe.
