at that price they will be made of air, covered in pressed/moulded hardboard, with thin battens round the edges.
Complete rubbish.
If you look at the edges you may be able to see the edge of the skin.
You can get a 6-panel solid core 35mm thick door, or a 44mm thick fire door, a lot heavier and more substantial. Made of chipboard basically but with a smooth paintable face. Probably around £80.
Those cheap doors are the same wherever you buy em. They're the kind you put in cheap rented properties so it doesn't cost you an arm and a leg every time the disfunctional boyfriend comes round to punch holes in them.
Tried some from jeld-wen, replaced 6 doors twice after they bowed due to lack of content, tiny piece of timber top and bottom and unglued piece of polystyrene, supplier eventually gave my pine doors at no extra cost.
