Hi all - I have searched your forum and seen various issues with the system that I have but none seem to be exactly the right answer for me.
Problem:- system age is 8 years - no issues to date at all untill now.
Timer advance button and programmed action fails to make boiler ignite on CH setting only, no relay click, no light on boiler =no heat .
confusingly timer Advance button and programmed actions correctly ignite boiler on HW settings- relay clicks & light comes on on boiler fans start and gas ignites as I expect.
I have the PCB25B board, as far as i can tell it all works - my fan relay showed signs of blackening under the clear case but the fan works fine.
Boiler ignites and HW works fine just no ignition and hence heat when CH attempts to start.
Both lights come on on the LP241 timer when button pressed- If I take the timer unit off the clock works ok so im ruling out the battery?
I have checked all connections for security and cleaned pins & reseated molex board connectors etc to check dry joints.
I need a clue as to what to look at next?
Cheers for looking
Cheers for looking
