Pilot lights stays lit, then main burner comes on for varying amounts of time then when main burner shuts down i believe the pilot goes out with it. any ideas?
No i havnt been there when its happened it my mothers house, will be going tomorrow after work, strange part was i fitted a gas hob the day the fault occured, but only shut gas off then re-lit boiler. going to test for 240v across L & N on gas valve. Cant find documentation on boiler. works fine for several hours then as burner shuts off the pilot goes out as i believe.
