I have and S plan central heating system (Gravity feed) and I'm trying to find a Manual for my circa 1970 Ideal E type RS 50N Balanced flue boiler.
The problem is that I think to pump is connected in the wrong direction and would like to check which are the inlet/outlet for the water connections.
When I moved in the control system was in a complete mess (Pump motor power supply was direct from the mains and running 24/7, zone valve motors were not working.)
I have replaced the Zone valves, Tank stat, room stat and fitted a new tempus seven controller and all seem to be working ok.
But as I say I think the pump is pumping the wrong way, pumping into the bottom of the boiler, if this is correct then the zone valves are at the end of the loop and are in the wrong way round.
If someone has a manual for the E type RS 50 or can confirm which connection is the inlet and the outlet, that would be much appreciated.
Cheers
Scott
Cheers
Scott
