Ideal Logic 35
1 Dec 2006
Cumbria
I have an Ideal Logic 35 that has to be topped up every day as the pressure is dropping & it eventually comes up F1 error code. I have also noticed that the diverter valve head keeps clicking on and off when the heating gets up to temp. and the boiler shuts down. Could this be the cause of the loss of pressure.Could the diverter valve body be faulty. Or is the pressure switch actuating because there is a leak ( perhaps in the heat exchanger) and operating the diverter valve. The leak is definitely somewhere in the boiler as it loses pressure even with the flow & return isolated and the boiler switched off.
If there is a leak within the boiler you should see evidence of it ,unless it is the heat exchanger where the water would escape via the condensate pipework and you wouldn't see that .
  • Like
Reactions: CBW
Yes that was what I thought, but I was hoping that there might be a possibility it might be a less expensive job.I also believe it might be the PRV or expansion vessel that's leaking but have not investigated that yet and was just exploring the things that were evident.
Good news, leak is, as jurassic sparks suggests, leaking PRV. The diverter valve clicking appears to be because the pressure goes low but not low enough to create error code F1
  • Thanks
Reactions: CBW
Get someone in to look at the expansion vessel.
you can check your Expansion vessel with the water pressure at zero, you should have an air charge of 1-00Bar in the vessel (it has a schraeder valve fitted and can be pumped with a foot pump or similar
P.S. the charge in the vessel SHOULD be checked annually when the boiler is serviced -I wonder how many bonus paid homeserve types have time to actually do this!!
Could that be another reason for the symptoms that are both happening. Parts have been ordered but no mention of expansion vessel. I use a local heating engineer but not sure about his experience with Ideal boilers although he seems to know what he is talking about.
  • Like
Reactions: CBW
Expansion vessels usually need pumping back up with air
Just thought I would look some more while waiting for parts and engineer to arrive next week because the clicking noise is getting irritating . Turned off the boiler at selector switch not main switch. Left to shut down completely. Boiler pressure gauge reading 1.0 but diverter valve head motor running continually then clicking every few seconds stopped after a couple of minutes. Thought I would test pressure in expansion vessel. Took off cap & fitted pressure gauge that showed around 1 bar. Removed gauge connector and a little water squirted out as though the vessel had a fair bit of water in it. Do these things indicate perhaps another problem?
