Hi all, basically looking for some advice/troubleshooting
I have the Ideal Mini c24 combi boiler and have an intermittent fault where it doesn't light properly. You can see and hear it trying to light but it then cuts out, ticks and you get the green rapid flashing error light on the far left. It will then repeat this process until you turn it off or it sometimes eventually fully lights. It does seem to be happening more often than it works now.
I've read around and tried to check for anymore fault lights but can only see the one on the front left but maybe I need to remove something? On its annual check I did mention the problem and he said it was fixed after he'd been (I wasn't personally in so not sure what he did)
I'll try and attach photos to show exactly which model I have.
Hopefully someone may know more than me!
View media item 96666View media item 96665View media item 96664
