Ginja, you seem to think that a repaired PCB for £70 is good value compared with £85 for a brand new one.
Your plumber may well be correct in saying the GV is failed and blew the PCB.
However, that makes me suspicions that fuse values are not correct! Whats the fuse value in the fused spur supplying the boiler? Whats the fuse value on the control PCB ?
Can you post a photo of the UNDERSIDE of your PCB with the burnt track so that I can hopefully confirm its likely to be a failed gas valve?
We would replace the GV and PCB for about £325 ! I suspect your fellow is giving a high figure because he wants the job of fitting a new boiler.
If you installed your own boiler then you would be risking illegal gas work as well as potential problems with the warrantee and notifying Building Control as fitting flued gas appliances are a controlled activity.
Tony
Tony
