Ignition Lockout - Worcester 24i
5 Nov 2006
I'm assuming this is a simple question to answer but I've not been able to find one through searching so here goes...
After bleeding two radiators my boiler began 'playing up', having searched through here I've managed to figure out that the problem was a lack of pressure. I've now managed to refill the boiler and have 1 bar of pressure as recommended but the red light on the front of the boiler keeps flashing slowly indicating that the ignition was locked out. How can I 'unlock' the ignition?
The advice on the Worcester website hasn't proved to be that helpful!
You beauty! I knew it would be something obvious... I just couldn't see a reset button on the front of any sort. Took the pull off front panel off and then realised that you just have to push the 'flashing light' in.
Many, many thanks!
