- Joined
- 31 Dec 2003
- Messages
- 169
- Reaction score
- 1
- Country
My daughter's flat has a combination water cylinder with an immersion heater. The heater does not work and needs replacing but so far I have been unable to unscrew the old unit. The spanner I'm using carries a warning about not using undue pressure as the cylinder may distort or even break around the heater boss. I've tried spraying WD40 around the thread but there is a fibre washer between the heater and the cylinder that I suspect is soaking it up so the thread is still stuck.
Does anyone have any tips as to how I may free up the old heater?
My daughter is resigned to the fact that she may have to replace the cylinder as well but money is very tight so if I can replace the old heater that would clearly be preferable.
In the top of the section of the cylinder is what appears to be the remnants of a circular pipe. The thing is in several pieces and is covered in scale. I think it's a sacrificial anode? Due to its current condition I can't tell how it was fixed into the cylinder but there seems to be a short section of pipe poking up from the base of the cylinder. A local plumbers merchant said he would just leave it as it is and anyway he doesn't stock replacements. The cylinder is 18" diameter.
If it is a sacrificial anode must it be replaced i.e. will great harm be done if I don't and if it must be replaced where can I get a replacement?
