Characteristics
The EB-Therm 100 is an electronic thermostat developed for optimal regulation of under floor heating systems. The thermostat has three modes of operation. You can choose between room thermostat, floor thermostat or a combination room thermostat with overheating protection in the floor. At delivery it is set in the floor thermostat mode but can easily be repositioned to the other modes.
Package
The EB-Therm 100 is delivered with front and frame suitable for Eljo trend wall box system. An optional front suitable for Elko rs and an extra frame suitable for Strömfors are enclosed. A 3 metre sensor cable is included.able are included.
Installation
The EB-Therm 100 is suitable for flush mounting or surface mounting. For surface mounting, an extension frame (E 85 816 68)should be used. The thermostat is approved for installation in wet rooms.
Technical Specification
Voltage 230 VAC ±10%50Hz
Air temperature range 5°C to 45°C
Floor temperature range 5°C to 45°C
Temperature limiter 15°C to 39°C
Load 250V 12A 2700W:
Main switch 2-pole
Load Cos φ 0,3 Max
Hysteresis 0,3°C
Housing IP21
Colour Polar white
INDICATION
Supply 230V connected Green led
Heating cable operating Red led
Max length of sensor cable 50m,2x1,5mm²
Suitable for Eljo trend,Elko rs,Strömfors and Merten frame system.
Installation instructions
http://www.ebeco.com/en/showpic_prod_spec.php?id=15&bild=5
