- Joined
- 27 Jan 2008
- Messages
- 23,707
- Reaction score
- 2,671
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My mother only used down stairs in the house all up stairs radiators are set to number 1 setting on TRV or turned off where no valve fitted so only three radiators and two towel rails in use.
In real terms just two rooms one used as a bed room the other as living room both with TRV fitted. The wet room and kitchen just have towel rails and the hall has one long radiator and no TRV.
The thermostat is in the hall and the stairs have a heavy curtain to stop heat going up stairs.
The afternoon sun will really warm up the living room and wind direction also very much effects the temperatures of the two rooms. Efforts to get mother to leave doors open has failed.
So next thought is:- Electronic programmable heads for the two rooms, to get rooms to required temperature, rather than the hall, either that or some electric head and wall thermostat.
However my son is telling me the by-pass valve will fail if it operates for too long? He tells me I must have a thermostat to turn off boiler, (a Worcester combi-condensation) and I can’t use the valves on the radiator to control heat alone. With a wired head I could clearly combine the two radiators so if either one calls for heat the boiler will run but the thermostats are normally single pole which means a couple of relays or maybe a PLC I have spare.
I have tried setting the existing TRV but don’t seem to be able to get a happy medium either mum complains too hot or too cold. With my home thermostat you can press the hotter or colder buttons and at next temperature change it reverts to programmed temperature some thing like this would be ideal.
So what head can I get for the TRV and do the heads have micro switches like found in motorised valves? Will the programmable TRV be any better than a standard head at controlling temperature? And are the heads all the same or do I need one special for that make?
Yes I know could use two motorised valves but they are bulky ugly things. Heads for existing TRV would be far easier to fit.
