Hi. Our washer dryer started with an intermittent problem whereby the dial would continuously turn when we selected the usual selection of easy care. It did however work on other programmes, then resumed normal operation for a while until now.
The dial problem has since returned at the rinse stage after a normal wash, without rinse / draining and no spinning, even after a reset. (i'm assuming with water in, it wont spin). I've checked the PCB connections, removed and replaced and have emptied the chamber that had a bit of wicker basket reed in, but the problem still persists.
I'm thinking it's the PCB due to the intermittency and variety of problems or the water pump. Can anyone please confirm this (or not). Many thanks Paul B
______________________________
Lynda, moderator
please note forum rule 9
Lynda, moderator
