Indesit, Ariston and some Hotpoint & Creda Washers and Dishwashers
no of flashes
1=short circuit triac
2=motor jammed check plugs
3=ntc open/short circuit
4=p/switch jammed on empty
5=p/switch jammed on full
6=prog selector managment error
7=heater relay stuck
8=heater relay cant be activated(common on new boards try tapping relays)
9=inompatable eprom
10=pswitch not sensing correctly
11=pump cant be activated
no 12
13=dryer fan does not work dryer ntc faulty
14=dryer ellement
15=dryer ellemnt not working dryer relay on pcb probable
no flashes but door lock led lit but fails 2 cstart check door lock motor heater and associated connections
were there is a lcd display all codes will be preceeded with an f except h20 =not filling
dishwasher fault codes with bit 100 pcb(written on serial no)
led1=overflow water in base
led2=inlet valve
led3=thermister
led4=timeout heating
1+2timeout draining. EDIT 1+2 can also be Software recognition error.
2+3timeout filling
1+3filters blocked
1+4software error
2+4heater
3+4timer hardware
EDIT For dishwashers with 7 Led's (BFI 68 etc ) read Led's 4 to 7 as code numbers 1 to 4. ie; 4 = 1, 5 = 2 etc.
Washers
a01=leak/overfilling
a02open/short ellement
inlet temp 2 high
half load selected but full load detected
a03open/short ntc
a04unable 2 sense temp rise within 70 mins
a05pressure switch check 4 blockages
a06=h20
a07 open circuit mtr
a08as above
a09as above
a10fill valve
a11valv motor module??
a12o/c heater
a13o/c s/s dispensor triac
a14syphoning out drain hose 2 low
hope that helps any 1 stuck
