Indesit Washing Machine - No wash
23 Jun 2008
Norfolk
Good evening all,
I have an Indesit IWC6125S washing machine that has decided not to work. The machine fills and imeediately drains with the wash light flashing. I have cleaned the pump and associated pipework from the drum with no joy.
Please help as the washing pile is gowing.........
Early morning bump. My apologies but desperate to get this sorted....
I think this machine has an anti flood device. Which is a float located at the bottom of the machine. check the float.
Make sure the water is not just flowing out of the waste pipe because the pipe is to low.
The washing machine has been working fine for 18 months and there has been no change to the set-up. The pump is definately pumping out the water.
Thanks for the reply.
There is no anti-flood device on this model.
Which number light(s) flash (there are several different versions & the wash LED isn't always in the same position).
On models with horizontal LED's count L to R (1-2-3-4). With vertical LED's count bottom to top.
Thanks for the reply :).
I have a vertical set of LEDs and its the top one, so number 4.
Cheers
The LED status indicates a shorted motor triac on the pcb. Before calling Hotpoint (who will probably offer to change the pcb for £100 including labour) try this: Check the motor connection plug is tight & there are no loose wires, then remove the pcb connection plugs one at a time & re-seat them. A loose/bad connection on either can throw up this fault. If that doesn't help the pcb is history.
Remember to pull the mains plug before checking the above.
