C
Coniferman
First of all, a few washes back there was a loud band from somewhere in the kitchen and the ring main circuit had tripped. The washing machine was washing at that time. Reset circuit, all seemed well.
For a while it has sounded like it is draining the water slowly. Water trickling into the waste. Have checked the pump and there is nothing stuck and the motor is turning. It does the 90 degree turn thing when rotated by hand (finger!). I have even removed and checked the rubber hose from the pump to the drum (not checked at drum end) and taken off the outlet pipe from the pump and no obstructions. On a recent 30 degree wash it stuck on spin and gave 5 flashes. I reset it and all was well. I decided to do a 90 degree maintenance wash which completed successfully.
The latest (40 degree) wash kept repeating the rinse cycles so I eventually had to progress it to a spin. Thinking this might indicate a water heating element failure, (possibly the bang?) I am currently running another 90 degree wash to test but already I can hear the water getting hot. (like the noise of a kettle heating up) So the element must be working?!??
So other than jokes about Indes*it, any ideas what the problem(s) might be and what other testing might be appropriate?
In case it is relevant, the hot water supply has been cold during recent washes. i.e. hot and cold supplies are cold water.
Also, I've heard mention of a fluff filter and condensor box. Does this machine have such a thing? The dryer does heat the clothes but takes a bit longer than expected to dry so if their is fluff filter it might be an idea to check it???
I will update if/when the current 90 degree test wash completes.
