Inside windows freezing up
Discussion in 'General Cars' started by Grundy, 6 Nov 2011.
  1. Grundy
    6 Nov 2011
    2
    Thanks Received:
    Glasgow
    Country:
    I have an 8 year old Toyota Corolla which runs great but in really cold weather I get a layer of ice on the inside of the windows,especially the rear screen, when it's been parked up overnight. Does anybody have a cure for this? Any help will be much appreciated.
  2. drewjak
    16 Oct 2011
    24
    Thanks Received:
    Country:
    try leaving your windows open slightly then any damp air can escape
  3. Belle427
    16 Jan 2006
    2,760
    Thanks Received:
    264
    Cardiff
    Country:
    feel the carpets for any signs of water ingress and use the air con if it has it fitted as it dehumidifies
  4. JohnD
    15 Nov 2005
    44,161
    Thanks Received:
    1,978
    Perth
    Country:
    I had this in my Toyota after having a dent fixed in a rear door. on examination, I found there is a polythene sheet taped to the inside shell of the door, which causes any water getting in round the window seals to to drip down to the base of the door and run out through the drain holes. In my case the sheet had not been taped back properly and the water was draining to the inside of the car. The carpet by this door was very wet.
    Worth a try.
    In your case check inside the boot and under the spare wheel for wet, since you say it is mostly the back window.
    It is very important to use the heater fan on "fresh air" mode not "recirculate" otherwise it keeps the moist air inside the car.
  5. Grundy
    6 Nov 2011
    2
    Thanks Received:
    Glasgow
    Country:
    Many thanks for the replies. I'll check for any dampness tomorrow, although I've never noticed any but perhaps I've not looked hard enough.
  6. westie101
    3 Jan 2011
    2,497
    Thanks Received:
    313
    Cumberland
    Country:
    I've had it with brand new Vauxhalls, in the coldest weather I put a fan heater in on a time switch. Guarantees a frost free and warm car in the morning
  7. big-all
    12 Jul 2004
    15,938
    Thanks Received:
    1,100
    Surrey
    Country:
    the simple fact is the moisture laden air inside the car freezes on the coldest surface [inside off the windsceen]
    as said remove excess moisture by drying out or ventilation
  8. Ricardus
    15 Feb 2007
    539
    Thanks Received:
    34
    Essex
    Country:
    I've actually picked up a couple of dehumidifiers from the £1 store that I'll put in the car when it starts freezing up - I know the aircon is supposed to dry the air out, but I've got climate control in my Golf and when its cold it wont run the aircon and I can't override it.
  9. big-all
    12 Jul 2004
    15,938
    Thanks Received:
    1,100
    Surrey
    Country:
    unfortunately your [i assume ]silica gel /crystals will not remove a lot off moisture and will need to be dried out in the oven probably on a daily basis ;)
  10. Ricardus
    15 Feb 2007
    539
    Thanks Received:
    34
    Essex
    Country:
    2 for a quid I thought it worth a punt. :D
  11. Belle427
    16 Jan 2006
    2,760
    Thanks Received:
    264
    Cardiff
    Country:
    the climate will still dehumidify when its running hot, it used to well in my passat
Loading...
DIYnot News
Similar Threads
  1. burts
    496
  2. kofi2003uk
    14
    657
  3. micktheframer
    808
  4. BOB D.O.L.E
    9
    1,570
  5. timgardner
    3
    962
Share This Page
