Hi
I am planning on putting electricity into my garage which is attached to the house. Would be grateful if you could check to make sure I havent missed anything.
My plans are:
Take electricity from the house CU on the RCD side via a 32 amp MCB and 6mm T&E cable through the wall (in conduit) to a 5 way Wylex CU with 100A 30ma RCD in the garage.
Then a radial circuit from the garage CU 16A MCB to 3 double sockets, 10 metre run in 2.5mm T&E.
Also a lighting circuit from the garage CU 6A MCB to 2 inside lights and 1 outside light (total about 400watt) again about a 10metre run in 2.5mm cable.
All cable will be run in conduit and the spare ways on the garage CU will be blanked off. Nothing particularly heavy will ever be plugged in although in future might want to put a tumble dryer in the garage.
Does this sound OK?
Many thanks
My plans are:
Does this sound OK?
Many thanks
