I have been asked to install a tumble dryer for someone. Do these all need an external vent? And I believe there is no drain to these? I have installed a lot of washing machines but never any dryers. Thanks.
Thanks do the condensers have a drain or a tray you pull out to drain? If it's a drain can it be teed in to the waste via a spigot on the kitchen sink trap.
Most (if not all) condensing driers have a pump that shifts the water up from the condenser to the catch tray at the front, the pipe that runs to the top container can be altered to drain into a waste yes.
You get a draining kit that has clips and a longer hose.
