Hi All,
I would like to install a doorbell transformer in my consumer unit to power a door chime. I've never taken the front of a CU before, and would like some advice as to whether this is a viable plan for a DIYer.
As I understand it, what I would need to do is:
Disable the power to the CU by turning off the main switch on the unit.
Remove front of CU.
Install transformer and connect wires to door chime unit.
Replace cover on unit.
My main questions are:
Is this a safe and straightforward job for a DIYer?
Would any Wylex doorbell transformer be likely to fit my Wylex CU, or would there be different types?
What type of wire would I need to use between the transformer and the door chime unit? - the transformer outputs 8V.
I presume that a doorbell transformer will output a DC current - in which case am I right in thinking that both + and - terminals will be located on the transformer itself rather than using a common negative supply in the CU?
Is there anything else I should be aware of?
Many thanks for any advice
Remove front of CU.
