Installing French doors
27 Jun 2009
Nottinghamshire
Just wondered if you has any advice or tips for me while I'm cutting and fitting a set of 1400 French doors?
I was told to order them 10mm overall smaller than what the hole was going to be in height and width.
It's a 9inch solid wall so there's no cavity to worry about.
Is it worth using DPM on ever edge? What would you use to fit the door with? What are the screws, packers, foam called? Should I use these? What's best in your opinion?
Thanks for your time and help
