installing tiles over tiles
21 Feb 2014
down south
i have a bathroom & shower install to do, customer does not want to risk taking plasterboard
apart. have offered to place tiles on top of original tiles. what i am worried about is the weight
off both tiles on top of new build plasterboard. original tiles are approx 6inch x 8 inch x 5mm and new tiles are approx 18inx12inx 10mm . plasterboard must be 12.5 mm. does anyone know if the plasterboard will take the weight. ??????
if not, any suggestions apart from smaller secondary tiles.????
( don't know weight of tiles )
cheers for the help
paul
Should be if properly fixed , same with existing tiles. I would tell the customer you're happy to do it but at their risk as you can't guarantee the integrity of either the old tiles or the plasterboard
thanks chappers
i thought so, just had to check, me being to paranoid i expect.
what do you reckon is best adhesive to use on top of tiles,????
also one more question, i got to pack out to same level with under tiles, do u think 24hrs is long enough to dry before adding secondary tiles over top, ????
thanks for reply
paul
I'm not a professional tiler , you would have to check which adhesives were suitable for using over the type of tiles you have already, again no concrete advice but would have thought so, but you would have to check the manufacturers instructions with regards to setting times
thanks for honesty chappers, not much activity in this section don't you think ??
thanks for advice thou
paul
There are a few decent tillers on here that will advise you, it's always a bit quieter on the weekends.
