This ground floor flat has concrete floor and ceilings. Open vented system, can't convert to sealed due to boiler instructions. Only realistic route for pipework is under 35mm floor screed. Chiselled out chase in screed with club hammer + electricians chisel.
I would have prefered to cover 15mm runs with 18mm ply but not enough screed depth.
Therefore have used PVC coated copper. This 15mm tube is coated with about 1mm thick pvc, is dark green, comes in a coil, is a pain in the ass cos it needs straightening before use, mercifully accepts normal fittings, costs a rudy fortune (£12 + vat for 3m).
I removed the skirting and some wall brick to hide the pipes in the hall way at least.
I will cover over with 1:3 mastercrete:sharp sand.
Any comments as to how it could have been done easier, better or quicker.
Screed removed concrete slab exposed!
And the other side of that wall !
