Hi, we live in an old semi that originally had a single storey garage and kitchen to the side. At some point in time, this was mostly removed and a two storey extension was put on the house where this was. However, a very small section at the back of the house remained and was converted to a store room. This strangely has a chimney above it, as I assume it was part of the kitchen in a previous era.
This store room has since been converted by the last owners into a downstairs toilet when they extended the back of the house and they made downstairs open plan. Problem is, this toilet is absolutely freezing and despite having the door closed, it creates a draft into the adjoining room.
It would appear that to create the toilet they have put a partition wall in and then tiled on top of it. But when I tap it, it sounds hollow as though there is no insulation in place behind it. So there’s essentially a void that is cold and is fed from the chimney above. I’ve capped off the chimney but as it’s basically a single skin wall, it’s still freezing.
I can gain access to this void by removing the roof tiles (which I will be looking to replace anyway) and I’m just wondering if I can retro fit some insulation in there to the back of the plasterboard and is this likely to make any difference to the room? If so, what would you recommend using to insulate? Boards, rolls or other materials?
The walls to the right and left as you walk into the toilet are the original double skinned walls of the house and so I don’t suspect they’re compounding the problem and that it is purely going to be the thin plasterboard wall that was likely put in place as a way of hiding the pipes etc.
Hope this makes some sense and grateful for any help.
