Hi, I have a Ravenheat White Star LS80 combi boiler, the problem is that it is not giving me constant hot water.
The problem started sometime last year when occasionally whilst having a shower the water would suddenly go cold.
However recently the problem as got worse and now it rarely gets hot.
I made sure this wasn't caused by other taps or appliances being used, as the problem stilled occured when nothing else was using the water supply.
The boiler seems to work fine - fans seems to go on etc - and when the hot water goes on you can hear the flames fire up inside. However without touching anything - and leaving the same flow at the tap - I can hear the gas flame switch of inside the boiler and therefore I loose the hot water. However the boiler fan etc still seems to be working fine.
Initially the problem was worst in the morning when I found I had to turn the heating on to allow the boiler to get started. Now however even that doesn't seem to work.
The same problem of the flame switching on and off has also started occuring with the heating system.
I feel this should be a simple problem to solve but my knowledge of boiler systems is somewhat limited.
Could anybody help?
Could anybody help?
