I seem to have an intermittent fault on my Baxi Solo 2 RS 50 boiler. When I demand central heating sometimes it works and sometimes it doesn’t. The hot water system is fine and the radiators do get hot when the system is running. I have fitted a new pump and also checked the pump overrun is working. The radiators are not fitted with local thermostats so the heating system is controlled by a controller in the hall. I have checked that this stat is not the source of the problem by shorting the two wires in the stat together (live and demand). I have noticed that sometimes if I switch off the electrical supply to the boiler and then switch on this sometimes allows the central heating system to come on – but this doesn’t work all the time. I have bought an overtemp thermostat but have not fitted it. The fully pumped system has a Honeywell 3 way valve fitted and I have manually locked this valve open so the central heating should be allowed to flow at all times. The demand on the timer is set to “On” i.e. on permanently. Pilot light runs fine. Any thoughts?
