Hello,
I have a problem with my potterham boiler. When the central heating boiler is on I can get continuous hot water. When the central heating is switched off I get intermittent hot water. The BG engineer came around and said that it is scaling in the pipes and it needs de scaling. He then recommend that I get a unit call hydropath and it will cost £150 to install.
My concern is that if I do go ahead and do this install it may not fix the problem. Therefore does anyone have an idea what could be the issue, if the engineer is incorrect?
Thanks in advance, H
