Based in Surrey down south got a project which is to gut a house, whats the cost comparison for Internal Blockwork Wall compared to Internal Stud Wall per M2 inclusive costs with labour.
Block wall spec is Aerated Block 3.6N 100mm(215x440mm) then 12.5mm plasterboard either side.
Stud wall spec is 100mm Timber framework packed out with Knauf earthwool insulation then 12.5mm plasterboard either side
Is there a foundation then?
I’d say the block materials will work out slightly cheaper but that’s just a hunch off the top of my head
Much more common to do stud tho - quicker
We put a load of steels in between ground and first floor so loading is no problem. But in essence what is the price difference between Stud and block finished costs?
