I have very old property. No damp course. 'solid' stone walls up to 3 feet thick in places. Not externally rendered. Problem - had a sparks do some wiring approx 5 years ago. I asked for surface mounted because of difficulty hacking out stone, it was only moving a socket. He insisted it be buried cabling and proceeded to hack a huge channel in the wall. He hacked so deep it breached the infill. (the stone wall construction is large stones inner and outer walls with smaller stone infill). He then filled over the plastick trunking with a sort of readymix multi mortar. This was then plastered over. Since then, every time it rains water literally pours in, running down the inside of the wall. sometimes it runs out of the electrical socket he istalled, which means the trunking must have filled with water. Yes, the trip switch goes. A couple of months after he did the work all the plaster fell off the wall and I had to have it replastered. A year later, had it replastered again. Have looked all over the outside of the property but cannot see any crack, hole etc where the water could be getting in and we did not have a problem prior to the wiring work. I am assuming that prior to the work the water was dispersing down the infill to the ground but since the internal stone layer was breached it is now finding an easier route along the trunking. Originally the sparks denied any fault, then his phone numbers changed now he has disappeared all together. So how can I fix this? He also did other work for me in an extension (breezeblock construction) and I have damp coming in where he hacked down the side of a window frame. Basically, how can I fix the first problem i.e. the damp in the front room?
