hi
weve moved into a house 11 years old, and i need to fit a shelf racking system to the wall.
im trying to work out if the rawlplugs for plaster board walls should go all the way through the plaster board.
I think (ive drilled) there are two layers of board each side of the wall, with a gap in the centre of the wall (approx total wall thickness 100mm)
i think the first layer is 15mm then a small gap then another board layer make up each side of the internal wall
i dont know if the rawlplugs should go through all the plaster layers and the prong bits end up in the main center gap or the prong bits only need to go behind the first layer of plaster board.
it will be shelfing for the whole wall floor to celing on those twin gap batterns and clip in arms (approx size of wall 2.3m high x 2.6m long)
Do they even make rawlplugs with about 30-35mm of shaft before the prongs that point outwards?
any advise appreciated
thanks
simon
thanks
simon
