Unlikely as insulated plasterboard pretty much performs the same irrelevant of the manufacturer. The only deciding factor is likely to be price and availability locally to you. Something which cannot be predicted by anyone on here.
British Gypsum, Kingspan, Lafarge, Knauf, they all make a thermal laminate board - all pretty similar. Just get the ones that are cheapest but bear in mind that there are different grades of insulation. The better insulation will obviously cost more, so make sure you compare like with like.
