And you seem to be forgetting that things change, and whilst it may be one PC on one place today, what happens when there are 2-3-4-more PCs wanting to share files? What happens when there is an audio/video library? What happens when there are multiple printers with different characteristics (mono laser workhorse, general purpose colour inkjet, high quality photographic)?Allenm said:You seem to forgetting the original question!!
That's disingenuous - it's the 802.11n standard that gives you the high speeds - what you're effectively saying is "don't worry if your kit ends up non-compliant with the standard that supports the speeds that were the reason you bought it, as you will always be able to use it at the older and slower speeds".I agree with most of your comments, except that the Pre-N standard is compliant with the 802.11g standard (and 802.11b for that matter), so the idea of being left with kit that is non-compliant is wrong.
I think 10/100/1000 cards and on-board ports are quite common these days...Also, yes cat5 supports gigabit (and probably alot higher!), however I seriously doubt that the PCs employing this LAN will be able to use anything like that speed!
