My wife wants to change our existing cooker which is a separate hob and oven to a free standing cooker.
At the moment the hob is cut into the worktop and the oven is in a separate carcass.
This means having to cut the necessary gap in the worktop so that the oven will slide in.
I can't remove the worktop to cut from underneath without doing extensive dmage to the tiles etc.
Is there a way to cut the worktop in situ without lifting/cracking the laminate?
The only way I've been able to think of is to use the existing hob as a templete, mark lines either side to give the required 600mm gap, drill a series of small holes then use a jigsaw to cut through the holes and break the top out.
This would mean having to do some tidying up afterwards to make a neat edge and I'm not sure how I would work around the bullnose.
On a scale of 1 to 10 my carpentry skills are about 1 but this won't deter the lady of the house insisting "it can be done".
Would appreciate any advice on the best way to proceed.
