Is this gonna hold?
15 May 2005
Heya,
I'm trying to build this ...Don't ask why (well it's part of a film camera crane :) )
(I know the sketch isn't perfect, it's a schematic draw I made with Word)
I'm not totally sure that this rig is going to be be safe, so I'd like to know what you think - in terms of loads and stress on the different parts.
The parts are:
A - "Lazy Suzan", the rotating base. Rated load 1000 lbs, so that's not what I'm worried about.
B - V-shaped metal bar (I think steel), 1/16" thick.
C - r-shaped metal bar (again, seems like steel), 1/8" thick.
I plan to use 1/4-20X stove bolts to connect A and B, and a 5/16" hex bolt between B and C.
Later on, C attaches with two 5/16" bolts to another part, which is not what worries me.
On top of the lazy suzan I intend mounting a 6-pound camera.
Any thoughts?
If I understand the diagram correctly, all the load will be going through the area where the bolt attaches B to C, but this piece of metal is only 1/16". Looks a bit suspect to me, but I can't calculate whether it would work or not. I would be happier if B was made of thicker material and if B and C had a greater area of overlap.
Bracket "C" requires a gusset plate welding to it and at least two bolts instead of one.
What does it fasten to?
I can't figure this diagram out particularly well either, you haven't included much information on it. Where exactly does the "V-bar" attach? How far does it hang off the "lazy susan" before it meets the right-angle bracket?
I have assumed your lazy susan weighs 1.7kg (I can't deal with Imperial units for calculations!), that assumes it is 3mm thick, a solid disc of steel 30cm across. Your 6lb camera, well that weighs about 2.7kg. So, you have a mass of 4.4kg centred around 18cm from the corner of your angle bracket. That is a moment of 7.76Nm acting on that 1" wide bit of 1/8" steel. I am not a mechanical engineer so I couldn't say how much the bracket will bend, or if it will even yield/fail, But I suspect that this will not be rigid enough for your needs. The bracket would act like a spring, and make the camera oscillate up and down too easily, and it would not hold the camera particularly level.
As Dave says, it needs a gusset. 1/8", that's only 3mm or so. Not very thick, and will be thinner across the bend.
The problem with the single bolt between B and C is not the strength of the bolt. The bolt would be in tension, metal bolts are strong in tension. However, you need a second bolt there to stop it swivelling about if it loosens off slightly.
If you can find someone who uses a package such as "Pro/Engineer", they can draw this out for you and it will tell you if it will work or not. I have seen some very complex structures designed on ProEng, with a few clicks the engineer was able to then show that it would work in stainless steel but not in T5 aluminium.
put a dogs head on it and mount the whole thing on the rear parcel shelf of your car. It'll look perfect. :LOL:
If you're going to use it to capture video footage while the assembly is on the move, the results will give you motion sickness, (IMHO :cry:).
Apparently my necks always on the swivel when I go to the pub! well thats what Julie says anyway. :LOL: :LOL:
Woah! No responses for days...and then suddenly bang!
So first of all, thanks for the replies, everyone. I don't know why I'd want to put a dog's head on a 12" lazy suzan, but'd definately give it a try.
Seriously, I built the thing, and TexMex might be right - what comes before anything risks yielding is undesired elasticity - because of that thin B bar.
Problem is, I don't have access to welding equipment. This whole venture was a use-what-I-can-get-at-Home-Depot kind of project.
So the easiest thing to do seems to be adding a second V-bar - thus doubling the thickness, which will make it less prone to shaking as well as to yielding. I'm not worried about the single bolt swivling.
OR, I might just take the whole darn thing off and attach a real tripod head to C and that's it :)
AdamW, a special thanks for the detailed calculations. The lazy susan weighs barely 400g, and the V-bar attaches at the optimal place (the center of the V joint), other than that everything seems correct.
I got rid of the whole thing - obviously it was not a good design.
I ended up mounting a tripod head to C, which worked fine and gave me the results I wanted.
Thanks for the feedback!
