Is this notifiable?
24 May 2007
Surrey
The hob is presently connected via an unfused spur from the ring(not good). I will be rewiring it so that it is connected to the allready connected cooker radial (6mm2 T&E with CCU) supplying the oven.
kevindgas said:
why?
surely it would be easier just to change the switch to a fused spur with a 3amp fuse
He never said it was a gas hob. :confused:
If podooser has a single oven that ought to have a 13 amp fuse protecting it somewhere.
A lot of the Electric Oven nowadays can just be pulgged directly in as if it where a Toaster.
Check the instructions.
