Hi, I wonder if I could ask those in the know for some advice please. My electric ceramic hob has just packed up and I am looking to replace this with a new induction hob. Both the old and new hob are rated at 32A. I have just checked my wiring (installed when the kitchen was fitted) and I currently have the hob (32A) and a built under cooker (rated at 6.5K) connected to the same wiring (two cables coming from wall connection down behind the cook). In my consumer unit there is a 32A switch. This has all be running fine for the past 12 years since the kitchen was fitted but I just wondered if this sounds correct - both cooker and hob on the same 32A supply. If the cooker is rated 6.5Kw does this not mean that this too would need around 27A?
As I said, it has always been like this and always worked fine - just wondering if it is ok for me to simply replace the existing hob with the new one.
UPDATE: I am aware that general wiring questions like this have been asked before and it appears to be ok to connect both hob and oven to the same circuit - my issue here is whether induction hobs are still ok or whether they maybe require more power? Thanks
Thanks for your help and advice.
