Hi
Wondered if someone could cast an eye over this setup for me.
Intitially had a standalone cooker on a 30amp circuit.
Have replaced the cooker with a electric HOB and a single oven. The Oven is rated at 2.5 KW and the Hob is about 6KW. The equates to about 35 amps, but as I understand it, this is ok as it is assumed not all rings will be burning at once with the oven on. Ive run a 6mm cable from the juction box to the hob (which in turn has a 6mm cable to a cooker switch within 2 meters of the cooker) and a 2.5 mm cable from the oven into the same junction box.
many thanks for any remarks.
