well guys it is indeed ampy automation, but no isolator!
The incoming fuse is 60amp looking at the beige cover, could of been changed to 100amp i guess and not had cover updated but 60amp should be fine.
Somebody mentioned something about 16mm? Could you enlighten me? The meter tails going to CU look impossible to get to other than cutting meter seals. I will buy some tails and ask dno to put them in just after he has pulled the service fuse? Is this the correct way of doing it?
