- Joined
- 27 Jan 2008
- Messages
- 23,789
- Reaction score
- 2,686
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
When it failed to start, there is no sound of it even trying to crank engine, just clicking in the boot, turning off lights, wait retry and it started as if there was never anything wrong.
So just in case put a Smart charger on battery, maximum charge rate 3.8 amp it dropped to 3A rate and then 0.8A rate but even after a week it had not dropped to the 0.1A charge rate battery showing 13.6 volts when finally taken off charge before next trip.
Even then would not start with lights on, used for 3 days lot of miles covered, and then refused to start even with lights off, turned of heater fan, retried and it started so not turned off until home and where I could re-connect the smart charger. The volts shown before switching on charger were 12.4 volt which seems rather low for a battery minutes after turning off engine.
So looking at a number of possible faults.
1) Battery.
2) Car having some thing left on.
3) Alternator not charging.
4) Engine management not permitting it to start.
I am thinking engine management most likely, it has never worked the stop / start thing, and some thing seems to stop the starter motor even trying. To run for 3 days without charging a battery when it still had a problem on first start, does not point to not charging at all, yet 12.4 volt straight after Parking seems too low for a battery just off charge.
Any ideas?
1) Battery.
Any ideas?
