Jigsaw Blade wear
21 Apr 2016
Ireland
Good Evening.
I have a Black and Decker Jigsaw. I fitted a brand new blade.
I then used it to cut through two 4ft. lengths of 18mm chipboard.
The blade was then totally worn out. Is this normal wear.
The blade was a C.K type C.
Any advice would be much appreciated
yes
you may get up to 5 times more cut in chipboard with a decent blade but they are consumables
depends on use
a cheap coarse blade like un ground 111c for chipboard if accuracy is secondery
fine cuts101a or b ground blade or 101ao ground for tighter curves
