Hi i have just fitted a towel rad for a friend he lives in a 2 bed terraced with 5 rads plus towel rad . Before i started he said all rads where hot after i installed towel rad i tried to bleed them all up. Eventually i did it as it is a really old house and all rad nipples have corroded. Anyway now i cant get the living room rad to heat up every other one is boiling hot this is the last rad on system i even put hose pipe on this rad and pulled water threw it stayed hot for a couple of mins then went cold again. Before you ask im not sure what boiler it is apart from it is really old f&e tank in the attic with cold water cistern on top of cylinder in the bathroom
thanks in advance for any help
