Hi
I'm fitting new cabinets in a very small kitchen
I'm using standard 800 cabs into the corners on the far wall, and with the 227mm gap I have to allow on each end there's plenty of room for them.
Problem is the total length of those cabs is approx 30mm too wide to line up properly with the cabs at 90 degrees to them.
I plan to trim 30mm off the back of the cabs on one of the walls, from the service gap, to get these to line up. Also then trim 30mm off the worktop which fits on the top. This worktop will also have the sink in, which is a 500mm deep sink.
This OK do you think?
