I'm seeing my electrical contractor tomorrow. He has been rewiring our 'new' 1950s house (for the first time!), and has already renewed all the cabling to the lights and plugs, and will be fitting the consumer unit. That will complete phase 1 of our refurbishment.
The next phase is that we are about to start work on what amounts to a garage conversion to provide a new kitchen, and the builder has specifically excluded electrical works, knowing that we already have someone doing the rewire. We have settled on the kitchen design, and I'd welcome some views on the likely wiring configuration before my discussion with the contractor tomorrow:
Cooking Appliances: Two ovens (both described as needing wired-in installation with 13A fuses) + combi-microwave (just says 13A fuse) + gas hob (for ignition only).
Other appliances: Fridge, freezer, washer, dryer, dishwasher, cooker extractor, boiler.
Sockets 4 x Doubles
Lighting.
I'm guessing that the cooker circuit would be 6mm cable, but wonder whether the appliances need individual protection. I'd expect to put the washer, dryer & dishwasher on a separate circuit and I'd like to be able to use all three at the same time without risking tripping out the supply to the freezer! The other appliances (which won't draw very much) could be on a second circuit, along with the sockets (for counter-top appliances etc.).
Does this sound OK?
Lastly lights: the kitchen will have a vaulted ceiling, and we don't want fittings in the ceiling itself. Instead, we are planning uplighters on top of the kitchen cupboards (there will be about ten of them), throwing light up into the ceiling space to be reflected down, together with downlighters under the cupboards lighting work surfaces. We would like them switched from a two-gang light switch, but have no idea how the wiring would be organised for such a setup.
Sockets 4 x Doubles
Lighting.
Does this sound OK?
