hello there, i am about to fit my cooker hood and have the twin and earth just above the side of the housing where electrician left it where can i fix a switched spur ie can it go inside the extactor housing itself surface mounted , or inside the false chimney if it was sunk into the plaster , or would it have to be outside the housing / chimney and have the switched spur flush/ surface mounted .I am guessing the latter but just wanted to check
cheers any advice apprieciated
andrew
andrew
