I am about to lay a laminate floor in a lounge/hall area. Probably use Floors2Go megaloc (classen) flooring.
Previously I have just used the underlay that was supplied with the flooring (i.e thin 1-2 mm white foam from B&Q, or silverbacked 2-3mm from Floor2Go). This time, I am buying the underlay separably from the floor as it can be purchased cheaper on-line (for a higher spec).
Fitting is on a concrete floor, and I have a choice between Silver Laminate Underlay (3mm, 0.5 tog, 19db sound reduction, built in DPM), or Sonic Gold (5mm, 0.9tog, 23db sound reduction, build in DPM), both from Tradepriced.
Is it better to use a thicker underlay, in the event of any floor imperfections, or can being too thick be a disadvantage?
