Undo the heater box and see if there's any fluff build up on the fan assy and the heater. Can't see the condenser it must be under the heater box it should be a big container that takes the fluff away , do them checks then as zipper says get a new toc they did change them on a upgrade due to be over sensitive. If it gets top hot ie too much fluff they trip out some trip at 110 degrees some at 170.
Scrub the part number I gave you earlier (that is the original 160C double TOC). Hoover Candy retrofitted 180C TOCS in all later models. The correct part number for this is 41034167 http://www.espares.co.uk/parts?k=41034167 Sorry for the mix up.
hi zipper - got and installed the replacement as suggested it was a different part number than the old one and fits perfect - washer on it's third test run now and it's drying fine !
thanks for the advice and parts info - v much appreciated !
