I have a flymo hover compact 330, about 7 years old. It has a 330mm blade hence the 330 in the model number. The motor is 1450watts.
The blade was/is past it's best and I have sharpened it so much it is now very much out of balance.
I came across an old (not working) similar model with a newer blade intact and in good condition. Rather than let it go to the skip I decided to cannibalize it for parts.
I realised that the model I had cannibalized was the one above mine, an 350 with, you guessed it....a 350mm blade.....
The only other difference is that the motor is 1500w, so only 50w more powerful than mine. The chassis and everything else is exactly the same....
Question:
Is the difference in motor and the longer blade purely just marketing nonsense?
I cannot see how an extra 50w is required for the 35cm blade. I assume it must be that is just the "model above" marketing difference.
Question:
