I am about to lay laminate flooring in the conservatory, but discovered now that under the old carpet that I lifted there are ceramic floor tiles (some are cracked). I always thought that there was just screed.
Now I am unsure about two things, and hope to get your views!
1. What underlay should I use? Something that has good insulating properties would be good, but do I need a DPM as well?
I don't want to lift the tiles, as if anything, I'd rather raise the floor a bit to bring it up to the level in the rest of the house, so I thought perhaps of using Fibre Boards.
2. Can I use self-levelling compound over ceramic tiles? There is an area around a door that dropped a bit.
